05 Forester X
I'm looking to replace my OEM spark plug wires with MSDs but I am having trouble figuring out which ones to get. I've read alot of threads about people having problems replacing the OEM wires and getting a proper fit. Has anyone done this mod and do you know the part number you used?
Thanks
The Modfather
in all honesty, the OEM wires are the best to get. You really won't gain anything with other wires except maybe a worse fit. Subaru's ignition system is pretty efficient as is. I say save your money unless you are going for the bling factor.
I replaced the spark plug wires on my '03 X with Vitek Ultra Series Wires. They work perfectly & look very nice. The wires are thicker, so they didin't fit in the factory wire holder, so I had to fabricate my own. If you go with an aftermarket wire, make sure they're the same thickness or be prepared to do some fabricating. :wink:
