J
Guest
I have an '05 XT which is parked out overnight on a slight hill with significant camber.
On particularly cold mornings, it starts fine but sounds like a tractor and is sluggish for the first 5-10 seconds until the noise disappears and all is well. I am not technically adept, but could it be lack of oil or a blockage of some sort. Levels look okay.
97 JDM S/tb Manual
Can you park it on the flat on night and see if it does the same thing in the morning?
J
Guest
Parked it on the flat during the day and the oil level wasn't great. Have now topped up and we'll see what happens!
03 2.5X 5MT
You are probably getting was is known as piston slap. It disappears when the car heats up right? If so, then this is most likely what you've got. It is a known issue and there really isn't anything that can be done.
J
Guest
Sadly it is still there this morning. I have visions of dry pistons gouging deep score marks up and down cylinders. Looks like I have a "slapper" :D
try parking it pointing round the other way.
could also be the cambelt tensioner btw - the sounds are similar and I wouldn't expect a my05 to be slappy tbh..
Steve
J
Guest
Discussion Starter #9
Happens when parked facing down as well...only in the cold though. It clears up approximately five seconds after setting off and power picks up suddenly at the same time.
