Anyone know the smallest size wheels that’ll fit on the 19’?
Is this the case even with low offset wheels? Such as the 15" Black Rhino wheels with +15mm offset.I have heard conflicting information about the 19's. From what I gather, if you have the base model or premium, 16 inches is the smallest you can go. Any model above those (Touring, Sport, etc.), 17 inches in the smallest you can go. I believe it's because of the larger brake caliper/rotors being used on the 19's.
According to Subtle Solutions and Black Rhino, they make no guarantee that the 15 inchers will fit on a 19+ forester. Neither have had the opportunity to test on the new models.Is this the case even with low offset wheels? Such as the 15" Black Rhino wheels with +15mm offset.
So this is confirmed?I have heard conflicting information about the 19's. From what I gather, if you have the base model or premium, 16 inches is the smallest you can go. Any model above those (Touring, Sport, etc.), 17 inches in the smallest you can go. I believe it's because of the larger brake caliper/rotors being used on the 19's.
I have this set up and have no issues whatsoever with stock suspension as well as with 1.5" lift now.I confirmed with Black Rhino that the 16x8 +15mm Boxer wheel won't work on the 19+ forester. So looks like 17s it will be.
So now the question is, has anybody tested 235/65R17 on stock suspension yet?
