I just brought a 2001 Forester 5 speed with 124000 miles. The only issue is that there is a small leak coming from behind the timing belt cover. I have confirmed the timing belt and water pump were replaced by previous owner. I can assume that either the water pump is no good or the mechanic did a poor job cleaning gasket surface. My mechanic says that its so small and the fact that HEADGASKETS have not been done and will probably go within the next year I should keep an eye on it and if HEADGASKETS do go just do the entire job then. He also said to flush radiator and add the SUBARU ADDITIVE. That might slow it even further. Any comments appreciated...
