1998 S
Hello,
I have a 98 Forester S and I have always thought that it is much more responsive when cold and then becomes sluggish when warm the opposite of what I would expect a properly tuned machine to perform as. Last fall I replaced the plugs and fluids and it did get a bit better but I still notice the same trend. After its warm, the response from steppin on pedal seems to diminish. Recently I recieved the P0304 code for a misfire. Any suggestions as to how I can get more bang outta this? I see O2, knock sensors, coil pack, and injectors being reasonable suspects based on other threads. Can someone please verify this and help me establish a method of pin pointing the cause? Thanks in advance!
Jay
1998 S
Aftermarket parts recommendations?
OK should I start replacing the previously mentioned parts, are any of the aftermarket parts mfg better than the others or is OEM the only option? Also, I would be interested in any suggestions as to where to shop for these online. Thanks again!
