Hey guys,
I wanted to know the biggest diameter tire I could put on the SH and this is what I found.
The stock Geolanders are 26.8"
I had a spare 235/75/15 Goodyear tire/wheel combo and mocked that up in the rear well. It fit with about an inch more in the rear part of the well and about half inch in the front part of the rear well to where it hits that plastic liner. That diameter is about 28.9"
With the plastic wheel well liner you could probably fit any size tire below 29"...saying that, some tires dont measure the same size in a different brand.
Then I took off the plastic rear wheel liner and that big obstruction in the front loosely covers a pinch weld of the car. You could easily take a hammer and bend that up and fit say a 30" tire in the rear well.
I understand the fronts pose another challenge. The strut/spring combo will come into contact with a taller/wider tire depending on your wheel offset.
So in conclusion, 30" is probably going to be the largest diameter tire to fit in the well. Just by design you cant go any larger without some major metal work. Just be sure you take into consideration a lift wont do anthing about the biggest tire size selection. I just wont fit.
I hope this helps
I hope this helps
