1 - 15 of 15 Posts
2009 FXT TTT 5MT
Hello,
My OEM battery is on the way out with the cold weather here, what brands (together with model numbers) can people recommend.
Cheers,
Scott
2009 2.5xt 6 Speed Swap version 8 6 speed sti trans with r180
I just went to local parts store. They offered two batterys from the brand they carried. I picked the one with the higher cranking amps. Works good.
Go with OEM its actually a very good battery. I have put the original from my 08 into my -01 Nissan. I replaced the one in the Subaru with another Subaru battery. I expect it to go another 100K miles.
2015 Highlander AWD XLE 6AT
Hello,
Cheers,
Scott
Scott,
You appear to be located in Stockholm, Sweden. Are you looking for recommendations for locally available battery brands and models, or for somewhere else?
HTH,
Jim / crewzer
2009 FXT TTT 5MT
Scott,
HTH,
Jim / crewzer
Hi Jim,
Whatever people recommend as we can get most things here. I've already tracked down a local supplier of Optima batteries for example.
Cheers,
Scott
OK. I'm not a fan of Optima batteries, so I'll pass on them.
Considering your location, I'd probably look into the largest-size (highest CCA) local name-brand battery I could find. In case of a warranty claim, this would hopefully make for quickly finding a fresh (recent manufacture date) replacement.
Varta?
HTH, and best of luck!
Jim / crewzer
Same here, have had too many fail on me in the past few years. Quality went downhill when they moved production to Mexico for the ones sold here in North America, but I suppose it could be different for European countries.
Ive had a red top for 2 yrs that seems ok but it was a gift (sort of). A buddy with a corvette has replaced his red top under warranty 2 times in the last 1.5 yrs. Quality seems very iffy on them.
2009 FXT TTT 5MT
Discussion Starter · #10 ·
Cheers for the replies everyone. It looks like "largest-size (highest CCA) local name-brand battery" seems to be the way forward.
Happy hunting! I'll be interested in knowing what you decide to install.
Regards,
Jim / crewzer
2009 FXT TTT 5MT
Discussion Starter · #13 ·
I went with a Varta D47 Blue Dynamic battery in the end. Nothing special but was the more powerful of the ones guaranteed to fit the XT.
The 540 CCA spec looks good!
Thanks for the info, and best of luck!
Jim / crewzer
1 - 15 of 15 Posts
