They will fit but they won't really work with the SF rear tophats. This puts you with running the newer rear tophats which need the newer tapered sripngs. Some of the SF dust boots, bumpstops, and such don't really swap right over to the SG struts (strut rod diameter and different rear boot attachment). It can be done though.
1999 s-turbo manual
sg struts
Thanks for your comments, do you know if any modification is needed to fit sg struts on the front of the sf chassis?
