2001 S Premium
Hey guys,
Im going a similar Route as other threads on here and its been discussed over and over again but im extremely torn as to what to do.
I have a stock 01 S with WRX Wagon Springs on new KYB GR2's, Strut bars F&R, and -1.9 Front and -1.2 Rear camber.
Rear:
Option A ($$$)
Whiteline 20mm Adjustable RSB - $150
Whiteline Heavy Duty Rear Mounts - $120
Whiteline Alloy Endlinks - $120
Option B ($$)
Whiteline 20mm NonAdj RSB - $140
Whiteline 20mm Bushings - $15
Subaru HD mounts - $30
Whiteline Steel Endlinks - $70
Option C ($)
Subaru Genuine Parts Forester Specific 20mm Sway bar - $80
Whiteline Bushings - $15
***Now for the Rear i am worried about the lateral link support tabs. I saw someone made something a while back (mo_boost LL support). Is there something i can still buy?***
Front:
Option A ($$$)
Whiteline 22mm NonAdj FSB - $150 (**should i go 20mm?)
Whiteline 22mm Bushings - $15
Is there a heavy Duty Mount option?
Option B ($$)
Option C ($)
There doesnt seem to be any cheap solution for the front of this car.
Throw some part suggestions out there.
I pretty much think I'm going with Option C in the rear except with alloy endlinks.
Is 22mm too thick for the front? SHould i stick with 20? I've been told by people that 22 in the front will cause problems as my wrx suspension is too soft (Springs/shocks) for the 22mm bar? I just dont want to have to go out and buy another one after.
Is there a front hd mount?
Id really like to stick with one brand thats why i didnt venture into Kartboy but their endlinks are always a possibility.
Looking to make a purchase the end of next week 6/11
Thanks in advance,
Paul
2013 WRX Manual
I'm a huge fan of Whiteline and Kartboy products. If I where you I would get Whiteline 22mm rear bar and 24mm front bar with Kartboy endlinks. You should replace the rear lateral links but I wouldnt worry about them right away. I am a believer in using what you got until it needs to be replaced. :biggrin:
2002 S
No need to replace the lateral links on an SF, they have a dual tab link mount from the factory that is pretty sturdy. The 03+ SG Foresters changed to a single tab mount that will snap off with too large of a rear bar.
If you're using stock WRX wagon springs, I would go with a 20mm front/22mm rear non adjustable setup with aftermarket endlinks and call it a day.
2001 S Premium
Any reason for the larger rear than the front, many years of gran turismo tuning :icon_biggrin: has taught me bigger rear will cause big time oversteer.
I would tend to think it should have a mildly bigger bar in the front to induce a tad bit of understeer just to enhance predictability in panic situations.
Let me know,
Thanks
2007 Forester XT
thats my setup
2002 S
Let me know,
Thanks
No real reason other than Whiteline didn't make a 24mm front bar. The car is neutral now especially with the adjustability of both ends(the front 22mm on the stiffest setting is probably close to a 24mm effective anyways).
