1 - 20 of 37 Posts
2001 Forester
I know there is a couple versions of this floating around and i wanna thank all you guys for making drawings and giving tips. I wanna share my version in hope that it may help others make their own in the future.
My father managed to find a "do not enter" sign that was damaged and placed on "our property"
Needless to say i cut off the damaged parts and put the scrap metal to good use :)
Here it is compared to the stock rubber like skid plate
When i redrilled the holes and made sure everything fit, i noticed that dirt, mud, salt, water and so on would still be able to get around the sides so i had a good idea. I cut up the stock skid plate and reused the sides that go up to the sides of the engine bay. Heres what i came up with.
So heres what it looks like on the car
Fits like a glove/sock/hat/pants. so on. :icon_razz:
After i made this, i went back and drew it all out. Im missing the measurement for the rear holes and if under the car, ill measure and post it.
I think i am going to paint it because i dont want people getting offended that i used a road sign. In fact this is most likely illegal in some way. Either way, Enjoy and hope this helps people out.
**DISCLAIMER: I AM NOT ENCOURAGING ANYONE TO USE A ROAD SIGN OF ANY SORT. I AM NOT RESPONSIBLE FOR ANY DAMAGE YOU MAY CAUSE TO STATE PROPERTY!**
2007 Outback 2.5i
Lol :biggrin: Nice! I like the plastic sides idea. I was thinking about adding the stock plastics to my skid but decided it was too much hassle. Btw, how sturdy is that road sign (how thick)?
2001 Forester
High intensity .080 (2/25) aluminum according to google.
Should be strong enough for some mild bashing because it was pretty tough to bend. Had to get creative with it.
2010 Forester Diesel
Great idea – as long as you´re careful. The strength of this plate is in no way comparable to a "real skid plate". A rally of off road style skid plate, should be 3 x the thickness and preferably with additional skids.
At speed above walking pace, the road sign material will tear on impact. So, be gentle!
M
2001 Forester
Discussion Starter #7
Were are you guys sourcing out the sheets of metal for something like this? None of my local hardware stores had anything remotely close. it would have to be 30x20.
2001 Forester
Discussion Starter #8
M
I doubt it will tear that easy. I've seen these shot with a shot gun and not go through! My saw had a real hard time cutting it and it usually zips through things like this and bending it was a whole nother story. This is probably 98.43% stronger then the floppy stock skid. So for now, im happy. :crazy:
But hey, if i can locate a better/thicker material, ill redo it. Just havent found anything close to this yet.
2001 Forester Slushbox
Well done and yes it's strong enough,your not driving a rock crawler.
2002 SG XT Auto
+1 for the plastic sides idea. Will be doing that to mine ASAP. Here's my efforts.
It's 3mm thick alluminium tread plate...
Resprayed with the correct Subaru font...
99 Forester
Hi, Well done Fuze911 and MDG. I am thinking of knocking up a plate using some 6mm ally treadplate I already have. I will have to get a local engineering shop to put in the bends it is beyond a vice and angle iron.
One comment the spacing of the bolt holes is better expressed in metric. Between the centres of the front bolts 500mm:
and between the centres of the rear bolts 70mm
Now a question on the plastic original are a couple of slots for the air flow - on some commercially available skidplates there are louvre vents - MDG's design will allow an air flow - but with the side plates reattached are there any overheating issues. My car does everything - including some towing so overheating is a worry even here in the UK.
Jon
2001 Forester
Discussion Starter #13
Jon
Ive driven with this skidplate for 8.5 hours to vacation in 90+ degree weather and i have had no issues whats so ever. Some of that time was sitting in traffic as well. I drive the car everyday and have not seen any temp issues as of yet.
99 Ford Escort
I'm not offended by the use of a road sign...I say dont paint it, it adds some color to the underside and it looks cool homemade like, going to have to copy
2001 Forester Dual-Range Manual
Thanks so much for this, will save myself $350 by doing this. Was going to go buy a sump guard but now I will save my money.
Thanks a great deal
Taza
Smooshed FOTY 2011
I went the OEM route and pulled a stock factory steel skid plate off an old '85 Loyale/GL Wagon. "Almost" bolted right up (slight modifications needed), but it's strong as hell, and looks OEM at that. $20 at the junkyard......
I went and *borrowed* a sign. Went and got it about 30mins ago.
It says 'sand dunes in repair keep off'. Might need a repaint.
2003 forester XS
man its not that easy to find old gl's around here ... I would love to get one of those ....... aren't a lot of junk yards around here and most wont tell you if they have a car in their yard if you call .
2001 Forester
Discussion Starter #20
^ doesnt look like much protection...even from the little stuff hitting the heaters. I bet its real strong were it really needs it though.
1 - 20 of 37 Posts
