2014 2014 Forester CVT
How do I adjust the time on a 2014 Forester Limited with multi-function display. Thanks. Barc
2014 Forester XT Touring CVT
http://www.subaruforester.org/vbulletin/f77/2014-2-5i-premium-how-do-you-set-clock-243618/
Page 3-49 and 3-50 in the owners manual.
Hold the button to bring up the settings on the MFD (as Shemeel said) and then go to DATE --> DATE --> Use the up/down triggers to get to the time area, highlight the hour. Hit the middle trigger (I/Set) to select the hour, then pull the down trigger to change the hour down.
For better directions and screenshots, see page 3-49 and 3-50 in the owner manual. Keep in mind the OM is also available on your "My Subaru" page on subaru.com.
I can't figure out how to change/set the minutes.
You might have to be parked to do that.
Once you get through the Date-> Date thing, you should be able to move the highlighted item around using the up/down triggers.
I know when I changed my time while diving, the Hour was the first thing highlighted, which makes me think that you can't change the date while moving, so you probably can't change the minute while moving either.
:shrug:
