21 - 29 of 29 Posts
MY11 WRX STi Sedan 6MT
EGR? Shum mishtake shurely......we have no EGR!
As for the BOV mod, I found it easier to strip the whole lot off, connect one pipe from maniofld direct to 'top' (furthest from IC) port and remove the T-piece where the pipework went back into the trbo inlet pipe.
Simon
Thought you'd come back on that :biggrin::biggrin:
Subaru's terminology not mine(and not necessarily Exhaust Gas Recirc)
99 UK S-turbo
LOL, yes not EGR at all......Will recheck on a better connection, but either purge or crankcase breather I assume!
Simon
2000 forester turbo
Discussion Starter #23
Simon /Don using the pic's on this thread which pipe do i block to save a bit of fuel as got to go to gatwick twice from b/ham all m/way.I saw this thred fron simon
Follow 'vacuum' piping from BCS to where it joins the intake piping (hard plastic where it goes under the manifold) pull pipe off and plug with a bolt (m4 from memory) fiteither a cap if you have it, or a short piece of pipe (with another M4 bolt) onto the intake pipe et voila - wastegate boost only!
if you can point it out
Cheers Kevin
As Simon hasn't replied, I think the place to split and plug, as you have the additional small bore pipe, is as marked below..............................
No doubt he'll come back and say its wrong :biggrin::biggrin::biggrin:
2000 forester turbo
Discussion Starter #26
ok done reset check lite ok. looks like orig MAF and seeing mine is a my00 might need a new MAF wheres the part number
2000 forester turbo
Discussion Starter #28
so what about 99-00 MAF are fitted also on nissan almera tdi
ref part :22680-7J600
best price about £40:00
21 - 29 of 29 Posts
