03 Audi
Hi,
I have the dreaded leaking cam cover issue going on so planning on ordering the gasket kit to do the job - full gasket replacement.
However what I can't find is the specific torque setting for the 6 bolts? Can you help?
Thanks in advance
Les
Lucas
2004 Forester XT Manual
Hi,
It is 10[Nm] each. Be careful with those bolts. It is easy to brake them.
And be sure you will replace 'half moons' as well.
Good luck :)
03 Audi
Hi Kontkret,
Thanks for the response, appreciate it.
One question, aren't the half moons part of the complete cam cover gasket? Or am I missing something fairly critical to the overall process..
Rgds
Les
Lucas
Hi,
Yeap, you missing smth :) The gasket is one thing and the so called 'half moons' is the other thing. The 'half moons' will fill the U-shape holes in the block.
The look like the one underneath:
If you want to get more info about the replace procedure my advice would be to read through the following post:
https://www.toronto-subaru-club.com/forums/technical-diy-write-ups-faq/169223-diy-valve-cover-gasket-replacement.html
and I put some additional info on my thread:
http://www.subaruforester.org/vbulletin/f115/forester-2-0-xt-blue-arrow-235465/index2.html#post2547314
Any questions give me a shout :)
