2004 Forester XT
Hey... I replaced my disc brake rotors all around. For some reason, the hub area of the rotors is surface rusting badly. Is this normal? Should I have painted this part of the rotor with a clearcoat or something?
Should I address this? It looks like crap, especially since I took the time to paint my calipers gold.
How should I address it? I'm thinking pull each rotor, hit the rust with steel wool, then mask the face of the rotors and spray a clearcoat on the hubs (??)
Would there be an easier solution?
Thanks!!!!
The paint needs to be rated high temperature. I like the Rust-Oleum BBQ black, since it goes on very light, so there's no build up. I suspect any high temperature paint would work. :wink:
My MODding Journal
none none
This is the reason I always get coated rotors like the Centric blanks. Painting it will work as well. You could also coat the mating surface of the hub-rotor and then the mating surface of the rotor-wheel with some antiseize.
