2007 XT, 5 speed, 129,000 miles.
It is getting worse. Accelerating with light to medium throttle, at 4,000 or so the motor intermittently "bogs" down and then catches up again as the revs go through to 5,000. I am afraid to test this with any more throttle.
Cruise control mantle light is blinking and the check engine light is on solid. Codes read were miss fires. This light comes and goes, but it is on more than off any more. I have seen this code for the last 2 years. If it is reset there is no change in the motor.
Plugs, timing belt are current.
