Ok - Looks like blanks.
You guys are great. :banana:
I have found these:
CENTRIC PREMIUM BRAKE DISC, FLOATING TYPE, SOLD INDIVIDUALLY -- 5 x 100 mm bolt hole pattern; 293.5 mm outer diameter; 12.9 mm bolt size; 22 mm minimum thickness; Features double disc ground finish that ensures parallelism, eliminates run out, and provides near perfect disc thickness variation; Fully machined surfaces provide smoother, quieter stops, and longer brake pad life; OE specification center-split core castings offer proper heat transfer and thermal efficiency for improved braking power and safety; With superior black E-coating on all non-friction surface to provide long lasting corrosion protection; Meets or exceeds OEM standards; With Centric's limited 90-day or 3,000-mile warranty.
Or these:
EBC ULTIMAX PLAIN ROTOR, VENTED, SOLD INDIVIDUALLY -- 5 studs and 11.56 in. diameter; OEM quality replacement rotor made to the same specifications as original parts using G3000 gray iron; Precision machined, balanced, and 100 percent one by one run out inspected to guarantee zero rotor distortion out of the box; With EBC's 12-month or 10,000-mile warranty excluding wear and tear or race use; Install this brake rotor yourself with the help of EBC's instructional video P/N E35DVD083 which is sold separately.
What have you found?
Please include some suggestions for pads!!!!!!
