2009 XTEn Manual
Wifey is getting used to her xten now
Just starting to fix a few bits
Her drivers seat seems to have some play in the right hand side runner causing it to "rock" slightly round corners :(
Is it possible to just swap the rails for new ones?
We could do with some roof rails and I'm keen to get some decent ones.
I reckon I can get a good price on genuine subaru ones E361ESA000
Though the don't seem to list them for the facelift SG
Any one know if they will fit?
You can get the Thule aero bars and feet for a SG, there are a few threads about part numbers under the European section if you do a search.
2006 STI
The bars you refer to will fit. I have them.
They cover MY03 onwards.
Regarding the seat, are you certain it is the rail not a loose bolt? My seat rocked slightly on the test drive, but on investigation it was just that the front bolt had worked a bit loose. A few turns off a spanner and it was sorted.
2009 XTEn Manual
Cheers
I did look at the bolts and they look OK
Might be worth throwing a spanner on them anyway!
