1 - 1 of 1 Posts
05 FXT, LGT
So every time I reset the ecu for whatever reason (doing work on the car and pull battery) the vehicle will not return to idle off throttle properly unless I go through the idle learning procedure where you basically let it idle with no load for a bout 10 minutes or so.
Anyway, the only places I've seen this behavior mentioned is when the ECU has been tuned. I'm curious if this kind of behavior is a good indicator that it has had a tune or not? I bought the '05 Forester XT manual used and I don't know what some of the previous owners did. I bought it as a project car anyway.
I also have misfire issues, and thought maybe a bad tune could cause both of these problems. After reset and the idle learn, the thing runs smooth as glass for a while, but eventually starts to run rougher.
Am I on to something or barking up the wrong tree?
1 - 1 of 1 Posts
