1 - 16 of 16 Posts
2001 Forester S
I have a 2001 S. There's a leak at the receiver drier intake pipe. The entire receiver drier is corroded and in really bad shape so I got a new receiver drier and new o-rings. Once I discharge the freon from the system and remove the old receiver drier, do I need to fill the new one with liquid? Or simply swap it out and then recharge the system?
Thanks
Mike
04 Forester X, MT
that corrosion looks pretty bizarre.
you're supposed to get the refrigerant sucked out and collected at a shop.
you need to pull a vacuum on the system with a pump and have a manifold gauge set to recharge properly.
Moderator
2004 Forester 4EAT
If there is still any freon left, have a shop suck it out. After that, you can do all of your parts replacing yourself. Then, have a shop vacuum it down, check for leaks, and refill. No matter how good a mechanic you are, A/C requires special tools.
2001 Forester S
I do have the a manifold gauge set and have recharged before. I believe there is some freon left. If I drive it to a shop and have them vacuum and collect the remaining freon, am I able to drive the car home and continue the repair - being that there is no pressure in the system?
04 Forester X, MT
It should have a low pressure cut-out but I would unplug the connector on the A/C coil for the clutch (on top of compressor) just to be safe.
I believe the green color is dye from the lubricant. A green dye is added to allow leak site ID.
You have lost some lubricant due to the leak. How much is hard to say. Most add 2-3 oz when a leak occurs. You need to ID the lubricant; PAG, PEG, etc.
I had to rebuild my AC when compressor rotor failed (split!). I used double-end capped PAG from ackits.com, a new receiver-drier, and used compressor. I air pressure-blasted the condensor, drained the compressor, and added entire 8 oz of PAG to system. I vacuumed for 1 hr, but most shops only do 15 mins. No problems so far. I added the PAG in the receiver-drier and compressor. You could also pour some into the condensor.
good luck
PS: The leak site may be the electrical pressure switch fitting. Another oring seal.
2003 Forester XS
Question I'm doing this on my Legacy (1995) same stuff.. but I have a question when they say leaks happen it's most likey the o-rings but all the o-rings or the orings at the compressor outputs?
Nevertheless to be safe I'm going to replace my o-rings and my leaky condenser and expansion valve.
1998 Forester
On a 1995 model it would not hurt to change all of the o rings. I would only use factory o rings.
2003 Forester XS
Trying to remove the evaporator but here is where I'm stuck.. I got the low side piping off which was the largest nut but I can't seem to get the smaller one off is it counterclockwise to loosen it because it feels like it's not moving at all.
You need to use 2 wrenches, one to hold the evaporator side male end and one to turn the female nut on the tube from engine side. If you released the large hose nut w/o restraining the male evaporator side, you may have damaged the evaporator tube (twisted and cracked possibily).
Get a shop manual!
good luck
2003 Forester XS
Get a shop manual!
good luck
I already have a service manual for my year and I did the same two wrenches like they show in the manual.. It's crazy how tight it's on! and I used PB blaster on it.
tread tape should help if I can get it undone and not mangled right? All this just to change the last few O-rings in the system....
Thread tape won't help seal oring seals and might cause problems. Use Nylog oring lubricant to get a good oring seal. Use antisieze sparingly on the male threads to ease future disconnects.
good luck
1 - 16 of 16 Posts
