1 - 2 of 2 Posts
The Modfather
Could not be simpler, it's up on the top of the motor where the spark plug wires start. A couple of bolts, wiring harness and spark plug cables to remove. You can do it and then consider yourself a real mechanic :) Only word of caution, do not use the coil pack as a place to rest your hand (putting your weight on it) because it may crack the plastic and cause all sorts of issues. I only say that because it's in the perfect spot for that purpose ;)
Some info here:
http://www.scoobymods.com/misfire-due-dirty-spark-t11994.html?t=11994
1 - 2 of 2 Posts
