I'm at a loss. I've managed to disconnect three 10mm bolts holding the drivers side headlight in place after I removed the grill.
There seems to be one more bolt in the lower left quadrant that is inaccessible. I also can not remove the side marker after unscrewing the one Phillips screw that drills into the headlight.
Is there some magic to taking off a 99SF headlight and side marker?
