1 - 12 of 12 Posts
2004 FXTi
After my wife cross threaded two wheel nuts, the studs broke off.
I just replaced the two broken studs. Used the instructions here:
http://www.scoobymods.com/replace-rear-wheel-stud-t4247.html?t=4247&highlight=wheel+stud
I did everything as directed but decided not to remove the ABS sensor, my experience being I'm more likely to break stuff like this removing it then by working around it.
I removed the tone ring and replaced the studs without any clear problem. I don't think anything wacked the ABS sensor...but I put everything back together and it seemed OK, but the ABS light is staying on. And the ABS doesn't work.
So, what are the possibilities for what got messed up?
Could I have put the tone ring on the wrong way (it looked to go on in only one way)?
Could I have gotten something on the ABS sensor? Can it be cleaned?
Did I just break the sensor? Are the sensors really fragile?
Any other thoughts?
Thanks,
Justin Wade
2004 FXTi
09 FXT Stage 2 4EAT
To answer you question about the sensitivity of the ABS sensor, the answer is yes they are very sensitive and a pain to deal with if you have to mess with it. I would go back through your install and see if you are noticing anything too lose or backwards. Good luck!
2014 CVT
the air gap in between the head of the senser and the tone ring, if it is 2 big or 2 small the PCM/ABS modules will not like the readings they see hence the light, if this is indeed the case they arent the worst to fix, you need some brass feeler gauges, and the spec, and a code reader
2009 Ralliart SST
sorry for this possible dumb question, the tech that installed my new wheel stud broke my toner ring. the subaru parts guy said i'd have to remove the hub to replace it. is that true or can you remove it without removing the hub?
2004 FXTi
Discussion Starter · #11 ·
To replace it you would have to remove the hub.
Another guy that broke his toner ring was simply able to JB weld it together, which was done in place, and so he did not have to remove the hub. If this was done at a shop THEY need to replace it and remove the hub.
Good luck,
Justin Wade
2004 FXTi
2004 FXTi
Discussion Starter · #12 ·
Oh, and in my case I bent the metal tip of the sensor installing the studs. I removed the sensor (which I should have done in the first place, it came out really easily), and simply bent the metal tip back to straight (almost). After driving for about 100miles it reset and works fine again. The metal part of the sensor is clearly very very robust.
Regards,
Justin Wade
2004 FXTi
1 - 12 of 12 Posts
