As many of us found out/know, the factory (OEM) remote starter has a huge flaw (they call it a safety feature): The engine turns off if any door is opened. In addition to that, the remote starter for keyless access models has a very limited range (uses the same key fob for both access and remote start) and the unit honks the horn when remote starting.
There has been mention of aftermarket systems such as Viper, Avital, Audiovox etc. etc. that may work with the 2014 + Keyless access. It's non-trivial to get these systems integrated with engine immobilizer and keyless systems. I've read here about hack jobs, having to leave a key fob imbedded in the dash and other nightmarish scenarios.
Does anyone have firsthand knowledge of a way to get a working remote start system that does the following:
1) allow for doors to be opened without the engine shutting down.
2) allows keyless access & engine immobilizer to function normally.
3) allows for a decent range (anything is better than the OEM 40 feet).
4) doesn't void the car warranty.
5) can silently (no honks) start the car.
My old car of 14 years had a remote starter and i'm already feeling withdrawal symptoms. I really don't want to install the OEM version. Engine turns off right when you open the door to drive off? Why? What were they thinking????
Help!
Help!
