Hi all,
I am assuming I need to replace a relay given the symptoms. I'm not too familiar with what relays exist for the headlights/turn signals so wondering if someone can point me in the right direction.
When I turn on my headlights I hear a click coming from under the dash on the passengers side & the headlights will come on. When I signal to make a turn (right or left) after it returns upon completing a turn (also if I move the selector to turn blinker off manually) I again hear a click from under the passengers side dash and my headlights will turn off for up to a full second. Also if the headlights are on & I turn the switch forward it will click & the headlights will go off for a second.
Wondering if anyone has had this experience before? Should I chang the blinker/turn signal relay or is there a headlight relay that could be replaced? I've not dug under that side of the dash, what needs to be removed in order to access the relays?
Thanks for any help you can give.
