1 - 2 of 2 Posts
2001 Forester L 5 speed Manual... For now
I recently did a head gasket job on my FOZ. However when I put the engine back in and started her up, im getting a code for P0444. are there any common things that i may be missing or forgetting about? Also when im fueling up it will constantly stop the pump. could these be related?
@Fozziebros. take a look at the link below. I'm going to guess it can be causing your fueling issue. :confused:
P0444 SUBARU - Evaporative Emission Control System Purge Control Valve Circuit Open
Possible causes:
• Faulty Evaporative Emission (EVAP) Purge Solenoid Control
• Evaporative Emission (EVAP) Purge Solenoid Control harness is open or shorted
• Evaporative Emission (EVAP) Purge Solenoid Control circuit poor electrical connection
Also...
1 - 2 of 2 Posts
