Bumper guard was brand new in the box and I got it from Andy Tang on here along with the rear spoiler and a few other bits...
The rear spoiler came with some pop in studs where you have to drill the tailgate and pop them in, as you wind the bolt in it spreads the pop in studs to make a secure fixing.
However the spoiler had been torn off Andy Tang's car by some vandals and the fixings were damaged, I decided to make my own bolts the correct lenght, I then drilled holes in the tailgate to locate the spoiler, I made my own template, I got some cardboard and cut it around the seating face of the spoiler, then placed it on tailgate and marked.
After drilling holes it was near on impossible to get the bolts into the spoiler as they are supposed to be screwed into the spoiler first then adjusted through the access holes to be tightened down. but the access holes did not offer enough movement for a straight allen key
As I was using allen bolts, I drilled 2 more holes directly underneath and fed them through connected to the end of an allen key, I also slipped a grommet over the bolts before screwing the spoiler down to give waterproofing and some "play" between the spoiler and tailgate.
