2001 Forester 4EAT
Does anyone know what the ECU "expects" to see from the rear O2 sensor? Before installing the spacer to solve the P0420 code, I was seeing around .8 volts at highway speeds and after, no higher than about .750v
This is a small decrease, but it still averages much lower. I have a few spare O2 sensors laying around from friends that I can try. What is the range that I'm looking for here?
Thanks as always!
2001 Forester 4EAT
Discussion Starter #4 (Edited)
Seems that the Pony Express module no longer exists from a quick Google'ing, I've located these specs for the resistor and a capacitor:
"You can use a .5 watt resistor 1 meg ohm and 1.1micro ferid capacitor"
Anyone able to confirm this and shed a little more light on this?
[edit] Oops, I lied... I found more info to chew on [/edit]
