I have a noise coming from under the back of my Forrester. 2.0X 2003.
The faster I go the louder it gets. It is a grinding / growling noise, which turns into a hum at speed. I have jacked it up and it is not the wheel bearings. The right hand rear drive shaft seems to have a tiny bit of play in it, especially where it enters the dif. Also there seems to be more play in the right wheel when you try to rotate it compared to the left one. The question is? Is it the Dif or the drive shaft?
Andy
Andy
