hey all, i brought my fozzy in december 2009, i had to change the brake pads in march due to passenger side was completly worn but the drivers side was fine, so i took it to a garage and they said without removing the caliper off that it was ceazed and that 4t wud cost close to 250 pound for replace and fit:icon_eek: , i thought that was a bit steep so i took the car home and my brother and i got the caliper off and new pads on, my bruv said that if it was seized we wudntv bin able 2 open the piston as easy as we did, so i thougt problem solved, nope i had to change them again due to the same problem so changed the pads again, i dont want to keep buyin pads every couplf of months, is it a common problem wiv the stock calipers like the garage said, i noticed the rubber around the piston had a few little tears in it, cud that be the problem and is there a repair kit avaiible for the stock calipers, or is it fooked, if i got some used wrx ones would they fit straight on to the discs, thanks guys.
