1 - 17 of 17 Posts
I got in a small fender bender the other day. this guy ran into me at a stop sign and did some minor damage to my rear bumper. On the running light its pressed slightly in and the attached pic shows a small hole punched in what is the under-guard i assume.. insurance guy just cut me an estimated check for $650 and told me if it costs more they would pay it.. the damage is neglegible but i would like to get it fixed.. opinions are welcomed weather to replace the bumber or just fix it.. i highly doubt there is structural damage inside the actual bumper.... in non-OEM a viable option?
Since the piece that was punched out is still there, I'd glue a patch to the backside of the bumper cover and press the tab into the glue-covered patch.
Then I would use some Mother's Back-to-Black and polish the cover ... as well as the bumper protector on top of the bumper and all the other rubber/vinyl surfaces on the exterior. You'll remove all the scrapes and scratches and be amazed at how much better your vehicle will look.
thanks for the reply... i think im just going to go to the bodyshop to see what they say.. i had a coworker look at it and he noticed the metal surrounding the gas tank was bent slightly.. better safe than sorry
Uh, I thought the gas tank was under the rear seats. I'm not sure how it could be damaged, but then I've been wrong before.
2009 Forester X 5MT
THat little hole will require you to replace the entire bumper. I wouldn't bother. I'd get this and call it a day. I have the same piece and I plastidipped it black. Take the remaining cash and run.
2010 XT Limited 4EAT
This, especially since it is matte plastic and will get dirty easy as long as there is no structural damage you will never even notice.
2011 2.5X Limited 4-speed automatic
I wish Subaru made the bumpers sturdier, with more of the impact beam covering the bumper (and not too much skirt material with nothing underneath).
Now you'll need to get the front bumper cover to match the rear...
Discussion Starter · #16 ·
i installed it and plastidipped as well... did not like the color it came in... blown away this part is actually $200... what a rip... but then again better than replacing the bumper :)
1 - 17 of 17 Posts
