I would also like to know what the fixes are for the rattles.
I noticed this not 5 miles into owning my vehicle. For anybody who has done this fix did it work?Peaty said:
polaris said:Rattle/squeeky noise under steering column - This is a known problem with Subaru. I had mine fixed the second week I had the car by the dealer. It is a wire bundle assembly rubbing against something under the steering column. They knew right away what is was and fixed it with some foam tape.
Now for the glovebox clicky click sound...
I finally figured this one out. This rattle is coming from the sunvisor mount, nearest the rear view mirror. There is a small plastic backing to the headliner right where the mount is. That plastic makes a noise when the headliner moves around on rough roads. I put a piece of felt between the headliner and the roof, cut a hole for the screw, tighted it all up and the rattle is gone. :Banane36:ogopogo said:I have an 06 that rattles above the sun visors. The headliner is rattles on rough roads.
Thanks for the idea.Retserof said:The glovebox had 2 rattles - the door itself and the lock tumblers. Instead of adjusting the the latch with washers, I fixed the door rattle by replacing the little rubber door bumpers with slightly larger ones. No fix yet for the rattle in the lock itself.
