1 - 20 of 21 Posts
2002 Forester S Turbo
As always lads, great advise ,thanks.By the looks of that pic and through the search thingy I think ure right removing the center trim doesnt get to the hazard button.
98 JDM Stb Manual
any one know what size bulb illuminates the climate control on a JDM?
and how to get at it
cant remember from the last time I had the dash out, so its not obvious
2002 Forester L
Anyone figure out how to get to that hazard switch and what type of bulb it takes? now that I know it's supposed to be illuminated it's driving me mad!!!
I also need to get at my rear wiper, its seized up and driving me crazy as well...
MY11 WRX STi Sedan 6MT
Does the hazard light switch light on the SF model up with the rest of the dash at night? Mine never has and its realy annoying me!!
According to the wiring diagrams - yes its illuminated.
According to parts - no separate bulb is listed, so its probably a "take apart" replacement or a new switch.
Don
2002 Forester L
I've heard of people in hotter, dryer, sandier countries using their left hand as a rear wiper. Hope this helps. :shrug:
I've seen what you speak of first hand (pardon the pun) while driving through rural India, Not sure how that info is going to help me free up that rear wiper though...
Thanks anyway!!!
2014 Audi S4 Black Ed Semi auto
Its easy to take apart, but a pain to reassemble. I did on a Classic Scoob about 8 years ago (twice, as I broke the first switch).
You can get a 2 or 3mm clear 12v mini bulb from maplins, with wire ends a bit like an LED.
The bulb carrier is a rubber holder and you have to wind the wires through some small holes and wrap them round so that it makes contact when you put the holder back in.
Its very hard to explain, but once you get it apart you will see how simple it is.
The switch actually has a Lexus logo on it, not that it helps.
2001 S Turbo Auto
same principle for other non-illuminated switches too, I hope...??? (on mine it's the headlamp adjuster 'wheel')
now my clock's failing, as is the heater control module lighting.
Knew i should've bought that XT instead. Damn!
1 - 20 of 21 Posts
