1 - 2 of 2 Posts
2004 X AWP
A very quick question: Can anyone explain the positioning of the knock sensor pigtail.
Am i right in thinking that if you take the centreline of the engine, ie front to back, then the pigtail is supposed to be at an angle of 60 deg from that line? if so is it 60 deg from the front end of the line or 60 deg from the rear?
Strange question i know, but having had a troublesome amount of 'knocking' or 'pinking' i noticed that the pigtail is currently at an angle of 90deg, ie at rightangles to the centreline.... would that be enough to cause the thing not to function as it should?
Thanks
Nick
1 - 2 of 2 Posts
