Here is some thing to think about that is pro warming your vehicle up in cold climates.
Most aluminum grades expand/contract at a rate of ~0.0905" over ~39.4"(one meter)(or ~.0023" per inch) for every 212 degrees F difference in temperature OR 0.0000108490" per inch per degree F. The engine block and heads are aluminum and our head bolts are about 10" long.
I will make the comparison from 0 degrees to a full warm engine ~190. Also keep in mind most mechanical fasteners in most standard assemblies have their torque values calculated as if it is being assembled at 70 degrees +/- 2 degrees and clamping loads calculated at operating temperature. So in reality by starting you car in 0 degree temps you already have a decreased clamping load on your head gaskets to provide a seal.
Block/heads
0.0000108490" (rate of aluminum expansion per inch per degree F)
X 10" (same distance as the head bolts)
0.00010849" (rate of aluminum expansion over 10" per degree F)
X 190 (deg F, difference from 0 to 190 deg)
0.0206131" (total growth of the aluminum block/heads over the ~10" length of the head blots from 0 degrees to 190 degrees of a up to temp running engine)
Now to be fair you also have to take into account the steel head bolts.
Not exact to the grade of the bolt but a mid grade steel has a average rate of 0.00000645" per inch for every degree F. Depending on the make up(alloy, heat treating..... this rate will change as it will with aluminum) but these numbers will make a decent comparison to get the idea.
Head Bolts
0.00000645" (rate of expansion per inch per degree F)
X 10 (approximate length of head bolts)
0.0000645" (rate of expansion over 10" pre degree F)
0.012255" (total growth over 10" from 0 degrees to 190 degrees F for the bolts)
Now to make that a direct comparison, keep in mind the engine is designed to run at ~190 degrees so these numbers would be reversed to figure out the loss in the clamping load at zero degrees.
0.012255" (difference in length of the head bolts from 190 to 0 degrees)
-0.0206131" (difference in length of the block/heads from 190 to 0 degrees)
-0.0083581" The difference between the high expansion rate of the aluminum block heads and the low more stable expansion rate of the steel head bolts.
What that means is at 0 degrees when you start that NA car that has a HG thickness of about .024" is you have lost 0.0083581" of material that would have multiplied the PSI being placed on the head gasket to seal it.
Now this is not the exact math going on in your engine due to a few reasons.
-The rates I used are for non alloys, alloys are typically more temperature stable then a straight up pure metal, Think the
gridiron pendulum designed by John Harrison. An alloy is a mix of different metals to achieve the properties you desire. So the real expansion rates will be some what different.
-Also there is no account being taken in for the Crush value of the Head gasket. Which is the number that the head gasket crushes to when fully torqued to spec. IE a new HG may measure 0.028" but has a installed height of 0.024". This 0.004" crush gives you some wiggle room, but not a full 0.004" maybe 0.001-0.002".
-There is also no account being taken for the elastic yield of the head bolts or the elastic yield of the threads in the block.
-These numbers are also going based on a full heat soak, all metal being the same temperature. Which does not happen evenly, it takes time. The engine warms up from the combustion chamber on out. So what that means is even though you coolant temp may be up to temp, the metal at the center of the block halves has no other source of heat transfer(no coolant, flame front as in the cylinder firing...) other then through the block it self or the. in other words the parts of the engine farther away the combustion chamber take longer to warm up and your coolant temp is not a true indicator of those areas.
So even though these numbers are not exact what they do show is that steel and aluminum have different expansion rates. Regardless of the alloy you are not going to over come that as long as the block and the bolts are made of two drastically different metals. That will result in the HG having less of PSI being applied to them to provide a seal as it warms up.
An example of this, my '03 Baja had a HG leak. It was a external coolant leak that would only make it self present if the engine was stone cold below 40 degrees. If it had been driven and parked for a 2-3 hours in 25 degree weather it would not leak. If you let it sit over night it would leak on start up and continue to leak until the coolant temp passed 100 degrees which coincidentally was when that area of the block/heads reached about 40 degrees. Proof of concept.
