1 - 11 of 11 Posts
2008 Forester Automatic
Looking online, I have found what appeares to be the exact same kit and part number, but prices anywhere from $175 to $300 (with water pump). Is there something I am missing, or are some folks just trying to make a few more buck than others?
Chris
1998 Forester S 4EAT
Im going to guess that people are just trying to make some extra money. Get it off rockauto. That has to be the cheapest place by far.
I use gates for belts, hoses and bearings. I used a Pronto water pump, my old job used pronto pumps and they seem to be very durable.
2006 Forester X Prem 4EAT
I've used the Gates kits before, idlers & tensioner are all made in Japan, while the belt is made in the US by Gates which is still excellent quality. However if I were to change the water pump, I would go with the pump manufactured by "Aisin" since it is also made in Japan... it is available on Rockauto.com.....
2001 Forester S auto
Yeah.. I probably shoulda used a quality Japanese made part... Instead I used this "Habuki". Hopefully it's not a bunch of "Dookie" Haha.... so far so good anyway.
2015 Forester 6MT
I used a Gates kit and AISIN water pump when I did my timing belt too, but only because the kit with the water pump wasn't in stock at the time. The AISIN water pump looked like good quality and came with the metal gasket
Discussion Starter · #10 ·
OK...bought the Gates kit and the Aisin water pump from Rock Auto. Did the install yesterday...took about 4 hours total, so not too bad for a first time. Air ratchet definitely helped speed up the process. Thank you all for your responses.
Chris
2003 Forester XS auto
Chris
Hopefully you torqued the bolts to spec and didn't trust the air ratchets stall point as achieving the correct torque.
Sent from AutoGuide.com App
1 - 11 of 11 Posts
