1 - 2 of 2 Posts
1998 Forester S
I found a gooood deal on some 2004 WRX STi stock springs that were only on the car for about 5000 miles. Would I be able to fit them on the Forester? (1998 Forester S) If so, how much drop would that give me?
99 UK S-turbo
Yes, and they will drop you about 2".
Fit them to your stock struts though and you'll have 2 problems
1/ The springs are too stiff for the dampers to control so ride will be poor
2/ The strut will be working outside it intended range and will be hitting the internal bumpstops quite a lot so life is shortened significantly
3/ The rear spring perch is 15mm lower on an Impreza so the rear will sit 15mm higher than intended.
Use Impreza struts!
Simon
1 - 2 of 2 Posts
