C
chelya
·Guest
I am wondering if someone has Prodrive P7 with 52 offset and if it fits Foresters ok. Are there any problems with it?
I need to know this as well asap !chelya said:I am wondering if someone has Prodrive P7 with 52 offset and if it fits Foresters ok. Are there any problems with it?
Thank you! I am not planning to upgrade my brakes, so it should be fine.pleiad7 said:I had the P7's with the 52 offset on my FXT for a while. They fit fine, but you will have less clearance between the wheel and the strut. Be aware that they definitely won't clear most BBK's if you're thinking about upgrading your brakes in the future.
Looks good! Thank you for the pic.CreoSTi said:Prodrive makes a +48mm offset on the P7's (for the Forester). These are the version I have on my FXT. However, if you're looking for any color besides Bright Flitter, you'll have to get the higher offset version.
Thanks.chelya said:Looks good! Thank you for the pic.
What size tires are those? I could not deside between 225/50 and 225/55. Finally got 50 - they were cheaper![]()
