1 - 10 of 10 Posts
Can anyone predict how my FXT will run if the map for the Prodrive Performance Pack was developed on FXT's running 91 octane - and I gas up on 93?
It's interesting to me that Cobb has maps for 91 and 93.
Will 93 octane make even better power?
Thanks -
11 sec club
04 Cayenne TT
I got 3-4 more hp across the board when I was with a stage 1 when running the 93 octane map versus the 91 octane map. I had 93 in the tank so the programming does make a small difference. I tried it just for kicks on my third run on the dyno since the first two were pretty much identical on the 93 map.
'09 STI
I doubt the flash will benefit from higher octane. I would think you'd need to change the timing to take advantage of it.
On the flip side, I don't think it will cause any harm besides to your wallet.:rolleyes:
thanks for the replies guys...
i'm stuck - and am trying to make my mind to go with the prodrive flash or the cobb accessport. i know that both are really good. i just think that it may make sense to use an off the shelf map that is designed to work with the type of gas i can get.
any other comments on either flash would be greatly appreciated...
98 Forester...what else
Umm...we're currently waiting for it to be released. There were some issues with another customer who I sold the PPP1 to, and we're waiting until it has been completely certified and cleared by Prodrive UK.
oh... thanks for the clarification. i thought that the PPP1 for the FXT was finalized...
2012 GTI DSG 6-speed
So a Prodrive Performance Pack reflash is an Ecutek reflash? Does that include a "tuner" and dyno time to dial in the tune for the specific vehicle or is it a shelf map? If it's a shelf map I'd say "what are you waiting for? Get the Accessport!"
The PPP is an axleback, a third cat delete, a silicon Y-pipe, and a PRODRIVE Ecutek re-flash.
Prodrive is connected to Ecutek in such a manner that they have special access software which can access parts of the ECU that other Ecutek tuners can't touch.
I was thinking about seeing what Simon @ Prodrive could do on Pleiads' Forester once we get a few more go fast bits on there.
Discussion Starter · #9 ·
roo -
any idea when the kit will be finalized? also - what were the issues that the beta testers encountered?
thanks for the info... :)
I'm waiting to hear from [email protected]
The issues have something to do with different ROM versions in the ECU. I sent one in for a re-flash, and this issue popped up. Ecutek is working on the solution as this is typed.
1 - 10 of 10 Posts
