I'd stay away from the bright yellow plastic encased consumer grade karcher electrics. We've had 2 of them and they always end up springing massive leaks.If you're going consumer-grade, be aware that cheapies have brush motors- rather than the induction motors of the better units.
Also be aware that the Karcher units in B&Q, Argos etc are very different to the pro-range stuff. Plastic pumps etc.
But yes, an inbuilt chemical injector is well worth having; just about everything is now auto start/stop, and there's really not a lot if difference in power between them all.
(I spend a bit of time repairing washers for a local motor factors...)
I have seen some in machine mart called Nilfisk, never heard of them. Could try out Wickes as you suggest. Anything a fellow geordie says must be right!Aye....stay away from the yellow Karchers. Mine only lasted 2 years of irregular use before losing pressure and their customer service people were hopeless. Took it apart and the pump head was only plastic bits and pieces. Try and get one with (as DPM stated) a brushless induction motor and a brass pump head.
I ended up buying a Wickes own brand (really an Italian make called Lavor I think) that has outlasted the Karcher and is a hell of a lot more powerfull.
Use them carefully at a distance from your paintwork, door/window seals, tyre side walls and valves and you have no bother - use them up close on drive ways and brick work and you be amazed at the crap they shift....along with your pointing if your not careful.
Not strictly true.............If you can attach it to a foam even better. Foam also strips wax though but helps to remove the crap better.
Agreed, if you use the right combo of products.Not strictly true.............
Well let's face it, foam will remove crap so it is bound to remove wax unless there is some magic to it :biggrin:Agreed, if you use the right combo of products.
:biggrin:
Yep it's magic - in the same way as using a rock will remove just as much dirt from your car as using the softest lambswool washmit will ... only with slightly less paint remaining afterwards :biggrin:Well let's face it, foam will remove crap so it is bound to remove wax unless there is some magic to it :biggrin:
I agree that by using the right foam you minimise the risk of stripping wax, someone did a test between foams in DW and the wax will last longer by using certain products but it will go in the end after weeks of usage.
