2007 Forester XT
I need to replace my power steering pump. I have no leaks in the lines but the car is getting the shakes when i turn the wheel at slow speeds.
I am looking around and see lots of options out there. The OEM is like $400 but I see ones that are without a import reservoir and remanufactured ones for less. Im not sure what I should be looking for.
2010 Forester Premium X AT
You may have already done, but have you changed out the fluid? If it hasn't been done yet, i notice that our vintage is getting to the point that the fluid is starting to look pretty nasty. I changed out some of the fluid and it seems to have caused a leak on the back of my pump, so i'm starting to look as well. I've only looked at OEM units, but havent seen any aftermarkets yet.
