Ordered 2'' Torklift EcoHitch last Sunday. It showed up on my door step on Thursday. Super fast shipping (and it's included in the price)! Hefty puppy.
I took the whole bumper off, taking off rubber donuts with rubbing alcohol (thanks for the tip E-Ticket), lowered mufflers, heat shield off.. Those were easy as pie.
Then dremel time, expanding one access hole per side - ouch. A brand new car. I was so not ready for it but this is more of a permanent fixture on this car, so do it once and get over with it. Good thing my wife didn't come out, or she would've killed me dremelling a brand new car. Left two big scars.
Then fishing bolts time. Never used this wire with spiral coil at the end to attach a bolt, how clever. First ones right below the expanded holes were ok, the ones closer to the bumper were royal PITA to get the wire through, took very frustrating 15 min each side. It was getting dark, so I started to swear - good thing my kids weren't out. Finally all 4 bolts hanging.
Then lifting the hitch to hung. I used my 2 ton hydraulic to lift up the hitch. Since I didn't remove mufflers (just lowered them), the hitch base refused to lodge in without a fight. Not sure if the rear end design changed for the '15, but spare tire well exterior lip (where tire tubs are welded together) is too wide, the hitch bar pushed the tire well lip up a little when installed. Oh well, that's how it went.
Also I had to cut the bumper about 3.5'' deep, rather than 2.5'' deep in the instruction - else bumper won't go back in completely. Not sure if something changed...
From there, it was quick putting the whole thing back together. Solid product with a very good powercoat finish. Did I mention they shipped very fast?
Two things that I rather have done, but couldn't/didn't were:
1) instead of widening 2 access holes, I wanted to remove bumper like OEM method to place bolts. Nope, these 14 mm nuts won't budge. I didn't have a lever for my wrench, it might have helped. But they are painted over, so they are obviously not designed to come off easily. How do you take these off?
2) Muffler removal - I wanted to just take off mufflers but again but they were solidly tightened, I didn't push. Hind side, I should've taken them off anyway, since placing the hitch between bumper beam, muffler, and tire well was just too tight. At one point the hitch rested on a muffler that was sitting on a jack stand.
Started at 4 pm, ended at 8:30 pm. I'm pretty handy but I would probably pay someone to do it the next time. Especially when there is not much to see after the installation :icon_wink:
Now I'm waiting for 1Up to show up. Taking a whole week for them just to ship. Must be a busy time.
