2016 Forester Touring CVT Automatic
2016 Touring - when the temp set point is set to LO and I turn on the fan the default mode is the air is directed only from the dash vents - would prefer the default mode be the dash vents and the floor vents - currently this requires one push of the Mode button - any way to change what the default is?
2013/14 2.5i-L CVT
If there is I haven't found it in nearly 6 years of searching. The climate control system is the only thing that bugs me about my Forester. If only it would revert to the last settings each time the car was started!! <expletives deleted>
2017 Forester XT Premium
My "17 reverts back to last used when I start the vehicle. Do not turn off the climate control before turning off the vehicle.
After 3 to 4 years of owning the vehicle you should know how to operate the climate control.
· Super Moderator
2014 2.5i Limited CVT
My "17 reverts back to last used when I start the vehicle. Do not turn off the climate control before turning off the vehicle. ....
While this is an answer, old conventional wisdom taught us to shut off a/c before starting the car to help eliminate stretching the belts, causing the dreaded squeal when starting the car or the AC compressor kicking on.
While most newer Vehicles probably have technology that limits the AC compressor from kicking on when you first start the car, thereby saving the belt, old habits die hard and it becomes a matter of habit to turn off the climate control each time you turn off the car.
Instead of turning the system completely off, when you're ready to shut down the car, just push the AC button in the climate control system before you turn off the car. This turns off the compressor, and leaves all of your fan and air flow choices in place when you start the car later.
At least that's what I do. I live in the desert Southwest - near Palm Springs - where we have many many warm days per year, so the AC system is in use probably 5 months out of the year... No belt squeal yet.
One other thought, when it came to the belts stretching issue on older vehicles, it was mostly front wheel drive with sideways mounted engines that had this problem. I don't remember most conventional mounted engines for rear wheel drive having that issue.
2013/14 2.5i-L CVT
Why should I need to keep auto climate control on all the time when I don't need it most of the time because the local climate is usually benign? Why should I need to hit mode every time I turn only the fan on to get air blowing at both my feet and face? Imo, it should default to the last settings.
2017 Forester XT Touring CVT
expletives deleted does not properly communicate the frustration of this.
