1997 Forester T/tb auto
Ever since i bought my jdm 97 t/tb, it consumes alot of fuel! i cant get anything above 15 mpg. Its the ej20g engine. Does not sound like its missing and i dont feel any hesitation. Engine is bone stock except for:
Mods:
Full apexi downpipe and exhaust (catless)
Things i have done so far:
Replaced maf with a used oem one ( due to stalling issues when purchased )
Replaced knock sensor
Replaced oxygen sensor (Oem bosch)
Checked for vacuum leaks (could not find any)
Ran a bottle off Marvel in my tank
Switched to shell v-power (91 octance)
Had the timing belt done and replaced crankshaft pulley
Emptied out a can of gunk air intake and throttle body cleaner into the engine until flames came out the exhaust! :Banane36:
Maintained tires at 32psi
Any suggestions on what i should try next?
As mentioned i did o2 sensor and i forgot to mention i did the fuel filter also.. i have friends with the same cars and they average 24 mpg.. i just want to get least 20 and ill be okay with that. i will do plugs soon. what plugs do u recommend?
