I've noticed that my A/C seems to quit working if winding the car out. The fans are blowing but vent temperature increases very noticeably. Does anyone know if the system response is somehow limited - for example, does it cut off the compressor above a certain rpm? Has anyone else noticed this? A/C charge seems good and I've only got 90,000 miles. Guess I need to actually test it.
Driving "normal" i.e. not like a granny but not going above maybe 4,000 rpm I don't really notice this. The air seems plenty cold. I do notice air seeming to warm up going over maybe 5,000 rpm or more. This is noticeable with "spirited" taking off or when fully loaded and towing and passing cars (winding out!)
I've not noticed this behavior on other cars with low refrigerant levels. On those, cooling performance seemed to drop across-the-board and A/C vent temp was higher than it should be.
