I know there are lots of engineers, technicians and generally smart forum members because I read the "What Do You Do" thread, so can someone please tell me what I need to use?
I did the Kicker speaker install today and it was a breeze except one of the plastic tabs on the inside of one of the rear door panels partially came off and I need to re-attach it. It's part of the (black in my case) plastic door panels that holds one of the eight little white fasteners that secure the panel to the door. It was definitely either glued or melted together at the factory (not molded). Anyway, the short question is, what kind of glue will stick to the kind of plastic that the door panels are made of? (I've never had any luck gluing this shiny/slick kind of plastic). Or, should I try to melt the plastic back together with a soldering iron?
Thanks!!
Thanks!!
