1 - 20 of 21 Posts
01 forester sport
i have developed this problem over the past couple days. ill be driving in 5th gear and all of a sudden my rpms will jump a couple thousand and i wont be able to accelerate at all. ill left off the gas , rpms will drop then ill be able to accelerate again. i don't know what this problem is. my best guess is maybe the clutch is slipping.... but im not familiar with clutches and how they work, please help me out!!!!!
tony
btw my01 forester sport 5 speed 192,400 miles.
2004 Subaru Forester XT 5 speed manual.
Does this problem occur in any other gear?
More importantly, are you accelerating in 5th when this happens, or are you just maintaining your current speed?
01 forester sport
subie roo - negative nothing. shifts fine through every gear. and no noises whatsoever.
evildan - it happened in third today on the way home from grandmas house. it happens when im cruising and accelerating.
I'd agree. This does sound like a clutch if it happens in many gears. A buddy's mustang was on it's way out and did the same thing. Tried to accelerate too hard, and it would simply slip, shifting was rough, etc.
96 Legacy 250T
I think they are right on the money dude.You have described the classic symptoms of clutch slippage. The only other things it could be is a contaminated clutch plate caused by a leaking seal where oil has got onto the plate which would be obvious once you get under the car for a look. Or you have something that has wedged in by your footpedal or clutch lever or a faulty return spring and it isnt releasing all the way.
does it matter if shifting is fine... its not rough nor does it grind going into any gears?
That's right. When you have your clutch pedal depressed, the clutch is not touching the flywheel. It has nothing to do how smooth your shift linkage shifts into a gear or not.
Clutches are friction based, sort of like a brake pad, and they bite into the flywheel. What you are describing is that either your clutch is missing lots of friction material, OR, *less likely* your flywheel is heavily glazed, or both.
HOwstuffworks.com how a clutch works.
YouTube - How Clutches Work
The clutch disc will cost $150 or so as stated, which is very little. They will probably sugggest resurfacing the flywheel depending on what they find, which is good to do on top of the labor to already have your clutch worked on already. Might as well do it while they're in there.
99 Forester
I'll make it simple. The clutch is probably wore out with 192,000 miles on it. If it fails completely the car will not move under it's own power. Let the clutch out and nothing will happen. It will seem like it's still in neutral. Once it starts slipping you have very little clutch left.
There is an outside chance that oil has gotten on the clutch as mentioned but you should see a significant leak. Either way the repair involves replacing the clutch since the oil will probably ruin the friction material (oil is kinda anti friction).
I don't think you are in any position to wait. Either fix it soon or park it.
99 Forester
It's not tough if you have some equipment. I pulled the motor out when I changed the clutch in my old Legacy. Probably one of the easiest clutches I've ever changed on a front wheel drive vehicle. I replaced the engine and transmission in the Forester and both times it went very well.
1 - 20 of 21 Posts
