1 - 7 of 7 Posts
06 forester xte
The plastic corrugated sleeve that surrounds the front offside shock absorber is loose and rattles when the car is driven..... any ideas how to re secure and so stop this annoying noise and it hits both top and bottom shock absorber.....the other shock absorbers have this sleeve and it seems to be attached to the top mount.
2008 Forester X Premium 5MT
I believe the bottom is free floating on the strut, the top however should be secured(not sure how). I would imagine one could either pull the top down and smear some RTV on the inside of the cover and put it back, or put a zip-tie around the top of it to secure it.
Is it the dust cover your talking about?
In that case the oem dust cover I had did secure to the top through a small lip.
However the newer ones I now got don't have that so mine just sits there loose. No noise that I can notice anyway. How can it make much noise anyway. It's made of rubber.... not plastic
2009 Forester (MT)
That should work. But I would just put three of four small globs or dabs of silicone around the edges to avoid adhering the cover to the top of the strut.
06 forester xte
shocker cover
Yes its the dust cover, im sure its moving up and down as the car moves and is rattling you wouldnt think it would make the noise but believe you me it does, thats what i think it is nothig else seems to be causing it.
none none
The dust cover gets sandwiched between the strut top and the bumpstop on the strut shaft. If you pull it down it will just pull the bumpstop down on the shaft. You can just push the bumpstop back up and it should hold the dustboot up.
1998 subaru
If the noise is present with a replacement shock absorber, check that the mountings are tightened securely, and look for other worn suspension parts.
1 - 7 of 7 Posts
