So I plan to do the head gaskets, water pump, timing belt, etc.. in spring. Currently I have 91K miles on it.
I know I have a small HG leak, currently running Bars Leak to keep it under temporary control. I have a "spare" car and can get an engine hoist and a stand for the motor. If I pulled it I would replace the rear main seal at least.
*If* I pulled the motor - what other seals should be replaced?
Would it be easier/better to pull the engine on my '01 Forester S (SOHC), or just do this in-car?
Recommendations, advice, and links to how-tos are all welcome.
2014 CVT
pull it!!!!!!!!!!!!!!!, there was a thread that had a list of stuff to replace, and a reason why you should pull the engine
Check the the DIY section in the Knowledge Base, there's a link to a write-up for doing HG's without removing the engine from the car.
