All,
I've been chasing this P0400 code for about a month now. Of course, my inspection ran up, as did the 10 day extension I received. Now its become fairly important to fix it. I wish I hadn't procrastinated when the light first came on :chair:
So, here's what I've done.
Replaced all vacuum lines associated (and some not associated) with the EGR system based on the Subaru EGR Diagram (I am friends with a manager at a Subaru dealer, so he and a tech there are also helping me with this).
Removed, inspected, and cleaned the EGR valve. It is functioning and clean now.
Replaced the steel lines associated with the EGR valve.
Replaced the BPT with a known good BPT
Replaced the sensors on the fender-well with known good units.
Replaced the filter that runs between the T and the sensor/switch on the fender-well.
Only other suggestion is to install an oil catch can, in case I'm getting a lot of blow by (engine has 220000mi on it) but the PCV and other breather tubes don't have an excessive amount oil in them. There was a lot of carbon deposits but we've confirmed that all paths are clean (vacuum testing and pressure testing after cleaning with SOA fuel injector cleaner). The tech has suggested that this is typically a long term solution, but more-so in high mileage turbo subaru's than the N/A Subarus... and even so, the CEL shouldn't return after the requisite two failed drive cycles after we cleaned it if everything was functioning correctly.
Is there anything we're missing? Should I just start throwing parts at it? I hate wasting money when we're using known-good parts.
Thanks in advance for any help. Everything I've done is everything I've found on this forum, Legacy forums, and other Impreza forums, as well as what SOA says in their '98 service manual.
