I'm taking my 2002 Forest in on Monday to have them look at what I think is a bad CV joint. Here's my history:
~85k, front right CV joint went bad (heard clicking when turning)
~90k, front left CV joint went bad (heard clicking when turning)
~145k, front right CV joint went bad (no clicking, but a kind of clunking/growling sound when coasting, went away when braking or acclerating, went away after axle replacement)
~157k, front left CV joint potentially bad (same clunking/growling sound, doesn't seem like bearing noise)
All services done by a dealer (two different dealers, though). The ones that were replaced at 85k and 90k were replaced with new, not remanufactured, Subaru axles (under extended warranty). I don't know if the joints that failed were the inside or outside joints. There were no torn boots on any of them.
I asked the service manager last time if there could be anything that's causing these problems, and he said no. But having 4 new Subaru CV joints fail without torn boots seems awfully suspicious.
So, does anyone have any ideas about what could be causing this?
The only theory I could come up with is that maybe my lock to lock range for my steering is to much, and this causes the CV joints to bend more than they should. The only reason I think this is that it seems that when I'm at full lock, my wheels seem to be not position quite correctly, and if I do much of a circle, it kind of seems to 'hop'. Hopefully that description makes sense (and I understand that this theory may not make any sense, it's the only thing I could come up with). I couldn't find any adjustment of steering range in the service manual, but I wasn't quite sure what I was looking for.
Thanks!
Scott
Thanks!
Scott
